Hey all-
So I'm picking up ideas/knowledge here and there about chassis setups. I have the stock suspension in my Formula right now (77) which, surprisingly, is pretty responsive.
The mill I put in (more detail in my journal, 383, ~425 horse or so) is exactly what I wanted for the car. I'm very pleased with it. First thing this next season the car is getting a shift kit and 3.73 gears. Trans is a TH350, 2500 stall.
Problem is I can already turn the tires over pretty good (posi unit) even from a dead stop, no brake torque and granny gears (2.73, currently). I realize this is going to hurt me badly when I do my 1/4 mile passes with the 3.73's. In fact, I'm wondering if I'm going to be able to hook up at all.
So my first plan of action is going to be to put in poly bushings and mounts all over the car, to reduce flex and optimize weight shift. I would consider putting the battery in the trunk, if you all think its worth it.
I think I probably need some traction bars and (sadly) I'm not much of a fabricator. I've seen trac bars for my car anywhere from 20 dollars to 400 dollars a set... where do I start? Keep in mind this isn't a 700 horse motor or anything, and its a street/strip car. I just need something functional.
My other consideration is subframe connectors. Are the benefits realized from these bars going to help me, or is it really just a waste of time to have them on the car for this type of application?
Lastly, I'm also worried about dynamic handling. This thing is still going to be driven on the street, so I won't sacrifice my front sway bar or anything just to make a launch once a month. Can I keep my rear leaf, front coils and sway bars and still be successful? Furthermore, are the body mods (trac bars, subframe connectors) going to hurt my handling through turns my not allowing the body to respond?
lol, why do I always write so much?!
Thanks in advance-
K
Thanks in advance-
K
