kleen56 said:
We have a debate going on with friends. What is the purpose of having a ballast resister on your cars wiring? Some said you have to have a ballast resister if your running points ignition. Others say you don't need a ballast at all and everything works fine. Any opinions? I'm talking about the square ceramic looking thing with a connection on both ends. Also, how do you know if the ballast is going bad?
Ballast resistors were used to drop 12 volts to 6 so a 6 volt coil could be used on a 12 volt system, and they were used on point systems.They cease to be used as the manufacturers switched to 12 volt coils and electronic ignition systems . Some had relays to supply 12 volts to the coil to start the engine and the relay would drop out of the start circuit when it started,others supplied 12 volts thru the starter solenoid then drop to 6 volts when the motor started.
So if a car has a ballast resistor with a 6 volt coil it is possible to change to a 12 volt coil with no resister as long as all of the other requirements of the system are met. ................make sure that it is wired right.
Hope this helps!
Kenny
Lost your job yet? Keep buying foreign.............
Oh ...to check to see if it is bad,use a volt/ohm meter on the ohm scale....no continuity....bad, high resistance ( more than a few hundred ohms) bad. Also with ignition in the start position ,a test light to coil side of resistor should light but wont tell you if it has high resistance.
Hope this helps!!
Kenny
