I am finishing up my first Nitrous install and have a question about the fuel lines. I am sure this is a very basic question, but this is my first nitrous install.
Since I am only using the 150 shot initially, I am feeding the carb and the nitrous system with the same mechanical fuel pump. I have installed a "Y" in the fuel line so I can feed both the carb and solenoid. I may not use the nitrous but 1 or 2 times a year at the most.
My question is, "since the Nitrous will rarely be used, should I have a shut off valve between the "Y" and the solenoid valve so there is not constant fuel pressure on an infrequently used nitrous system.
thanks
thanks
