You can easily use the 1997 PCM, you will need to get a 454 calibration installed..
Are you using the stock 350 4l60e or will you be swapping in the 454's 4l80e?
If you intsall the 4l80e, you will need to accomodate the 4l80e's extra speed sensor, and aslo correct the shift strategy via PCM programming.
The Vortec 350 L31 is rated at 255 hp and 330 lb/ft torque, the Vortec 454 L29 is rated at 290 hp and 410 lb/ft torque.
the Vortec 454 uses a larger exhaust than the Vortec 350. i suggest Hooker Competition headers. You will need to weld 1 O2 sensor into each header collector. You will need to either install catalytic converters or delete the rear O2 sensor reporting via PCM programming. The rear 2 O2 sensors tell the PCM if the cats are there and functioning properly. I assume
you have the 454 truck sitting there so all the parts you will need are there.
If you dont like headers use the manifolds from the 454 along with the headpipes and cats from the 1998 vehicle. Then yuu just screw in your 2 precat and 2 post cat O2 sensors into the 454 exhaust.
PCM tuning can be done by Fastchip, PCMforLess or Wait4MePerformance.com.
fastchip did the PCM tuning for my truck. You will need to tell them EXACTLY what you are doing here. PCM tuning will wake that 454 right up.
this swap is a bit of work, but is by no means unattainable.
The 4l60e trans wont like the 454 for very long. you can get a 4l60e rebuilt to easily take the stock 454 Vortec.
While the engine was out, I owuld be sticking a perfgormance cam in that 454. The Vortec 454 uses a 24 lb/hr injector, the 350 uses a 19 lb/hr poppet injection system. The injection in the 454 is superior by far. teh Vortec 350 uses injectors that limit power to 400 hp. these injector cannot be replaced by larger inkectors unless you use a different intake manifold. I am using a Merc Marine intake in my Vortec 350 with 29 lb/hr injectors.
If you have any questions, post back You are basically doing what GM should have done.
When you get a smog check, do you have to pass a visual? do they hook into the OBD2 connector under the steering wheel? Do you do an exhaust test??
peace
Hog
