Hi all my first post here.
I have a 454 with LS6 heads and i took on water in the #8 and # 5. All cylinders tested at between 135lbs and 150lbs except those.two which came in at about 70lbs. I took intake exhaust and heads off and found gaskets to be in good shape. Doesn't look like I broke anything. After looking at the head gasket I saw that there are water passage holes not open in the gasket. There are 6 half inch (aprox) holes on each head and in the block, on each side. In the gasket the top three have small 1/8 inch holes punched out but the rest are covered. The same on both gaskets. can anyone tell me if this is normal? The engine was rebuilt last year by the previous owner who passed away so I cant ask him.
I can post pics if needed all help would be great.
Thanks.
Thanks.
