1 - 20 of 21 Posts
Hi, ive got a 396 i believe crank with a casting number of 3804815. I cant find anything to match those numbers, ive found 3804816 and 3904815 but not what mine shows, here is a pic of it. Just trying to see if its cast or forged so i can sell the rotating assembly i have lying around. Thanks in advance!
Can't tell because of angle/clarity of pics. Don't have my crank book with me. Looks like cast.
Rule of thumb. If the parting line on the side of the crank throw is only a line, up to 1/16" wide it is a casting. If the line is 1/4" plus and looks like it has grind marks on it. It is forged.
Stand crank on end, on a shop towel. Rap a counter weight with a hammer. If it goes "thunk" it is cast. If it rings clearly, like a bell, it is a forging.
Thanks bob i think its cast also, im at school now so i cant take a better look at it to tell but i think i remember the parting line being very thin so its probably cast. What would would be a good selling price for the whole assembly, 10/10 crank, forged trw pistons on gm rods, its a 427 rotating assembly all fresh but has sat for awhile.
In the bottom pic, you can kind of see on the bottom throw what looks like grind marks like it has been clearanced or something, would this be a mark of the forging process you were talking about if its not cast? Thanks again
Hard to say on price. I can't sell 396-427 stuff. Everybody around here wants 454-500+ stuff even tho they can't afford it.
Prices here, good crank cast $150.00
rods, good bolts recon $200.00
Old TRW forgings around $200.00
Yeah i kind of figured that, well i'll try selling the stuff for the prices you listed and see what happens haha. Thanks again Bob! Anyone who might be able to identify the crank by the number id really appreciate it. Thanks
Discussion Starter · #8 ·
I was told it was a 427 rotating assembly so i assumed he just had a 396 crank and rods laying around as well as a 454 block so he made it a 427 + .030 assembly. When you say the different sizes, you are referring to the counterweight thickness correct?
Get in, sit down, hang on
Pics and more info fom BBC Parts Interchange Manual.
yes the thickness of third counterweight. 396 has a lighter rotating assembly if it is a 396 crank and making a 427 using 454 block probably should have everything balanced for longevity. you can't mistake steel crank. it has a wide parting line. just put a 3/4 end wrench on it it will either fit or not
Discussion Starter · #11 ·
okay, thanks 1932 batman. I will check it out next time im home but i believe it to be a cast 396 crank not sure why nothing matches the casting numbers though... Its all balanced and im trying to sell the whole assembly to get a 489 kit.
Sorry its been awhile, it has a wide parting line like a cast but rings if i hit a counter weight with a hammer lightly like a forged...
Read it again ...
WIDE parting line = forged
Rings like a bell = forged
3804815 = forged
366T/396/402/427/427T 3.76" stroke.
Discussion Starter · #14 ·
Shoot, i think i meant to say it had a thin casting mark like a non forged. Now im just confusing myself. If that casting number comes back as forged like you said then it must be forged. Yippee! thanks man! Now to decide whether this short stroke higher rev combo will live in a studded 2 bolt or to try and sell it and get the 489 kit that I really want...
FWIW ... I had a new Scat cast crank 910454 installed and balanced in my 2-bolt main 454.
My machinist "guarantold me" that I wouldn't have a problem running my engine up to 7,000 RPM, and I have read much the same on many internet forums.
David Vizard, author of How To Build Chevy Big Blocks on a Budget seems to have good things to say about them, too.
According to him ... (page 32)
A GM factory Forged Steel crank (like yours) has 120,000 PSI strength
A GM factory Cast Steel crank has 80,000 PSI strength
and a Scat 900 Cast Steel crank has a 110,000 PSI strength.
Discussion Starter · #16 ·
Oh wow, those cheap scat 9000 cranks are pretty solid. Im going to look into a kit with one if I can sell what I have. Will the 432 rotating assembly work for what I have though? All I have so far is the rotating assembly block and heads
It will go in a 2wd shortbed chevy street/strip
454 block .030" over
427 crank making 432"
781 heads 2.19/1.88 118cc chamber
Hydraulic roller cam im thinking something in the .600" lift range to take advantage of the head flow
Dual plane intake
th400 that will be built and whatever recommended stall converter
Rear gears will be decided at the same time
The main issue i see is very low compression, 9.07:1 with the 16.5cc pistons I have. I dont think that would make a good combo. I wanna make around 550hp for whatever thats worth
WFO
I'm purdy sure thats a 3904815. Makes it a 396,402...cast, nodular iron according to Mortec and others. Look closely at the other "8" and see the difference in the center of the digits. The "8" is straight across where the "9" is slightly slanted. ;)
As far as 'ringing' a crank to tell if it's forged or cast, unless you have a hell of an ear for it- as in you handle cranks daily- you can't tell cast from forged. If you have two similar cranks, one forged and one cast, they'll sound different but unless you know which is which and ring them at the same time, all you'll know is they ring differently.
Dual plane intake
Using Summit's Compression calculator with your numbers...
4.280 bore (4.25 +.030)
3.76 stroke
118 cc heads
-16.5 cc domed pistons
assumed .020 piston-to-deck clearance
assumed Felpro gasket with 4.370 bore and .039 compressed thickness
I get 8.69:1 CR and 432.77 CID
Using Wheelspin's calculator
I get 8.65:1
I've just removed my 781 heads and replaced them with 063 versions (68/69 396 closed 101cc chambers) hoping to get around 9.0:1 with my flat-tops.
Your setup with 063 heads would be awfully close to 10:1 ... which is right where you probably want to be.
From what I have read in regards to quench, decking the block to 0.00 would give you good quench and an additional .4 (10.4:1) compression. I also think, again based on what I have read, that the "perfect" CR is 10.25:1
I would also point out that you're obviously giving up some cubes with that shorter stroke. Is there a reason that you want or need to do this?
1 - 20 of 21 Posts
