1 - 15 of 15 Posts
Banned
I'm going to put together (fingers crossed) this winter my bbc stoker
looking on picking a few peoples brains.. as I'm sure a lots changed since 2002 when I bought all the parts for this build...
it's a standard bore 4 bolt 454 that will be bored 30 over and to piston to wall clearance that srp list for the pistons..
the pistons are dome type yeilding a 10.2 to 1 static compression with 118cc heads... my heads are 121cc
srp doesn't list it but I'm going to guess that their compression listing is with the piston at zero deck...
the intake is a dart single plane.. picked single plane as I plane on efi down the road and it's not going to loose to much low end at 489 c.i.d.. and in efi.. it not be much of a factor..
the heads are darts pro 1's 345cc(not cnc ported) but will be port matched to intake gaskets the intake valve is 2.3" and the port flows398 @.800lift/28"
the exhaust port is raised .3" and exhaust valve is 1.88" and port flows 266cfm port is 129cc
the cam is a solid roller
I have a 3 piece timing cover and the "hex-a-just" timing set to play with the timing to "dial in the power" at the track..
I haven't done anything but have the block magged..
in an engine like this what to I leave on the table not bringing the piston deck to zero?
untill efi I have 5 carbs to test on it.. 3310 750 vac 2nd, a 750 d/p and a 850 full race bearclaw, a 800 cfm q jet, and a standard q jet,
I have 2 dissy's a MSD billet and a g.m. points type converted with a crane convertion kit..
the bottom end is all good stuff as I plan on spray (2 stage)
lunati crank (4.25" stroke) and crowler rods (6.385")
full rollerized s/s rockers and arp everything... and march serp belt system...
windage control /etc/etc
what you say... bench race this...
was going in my 70 chevelle, but thats gone.. so it'll be in my 71 c-10 3800 lb's, th400 g/v and reargear up in the air, stall converter I have is 3300-3500...
anyone have a dyno sim.. to get a over inflated hp/ft lb numbers out of..
should I look at different cams?
truck will be a weekend toy/ summer toy with some track time..
spray will be after I get it to hook on its own.. if that ever happens..
Flame suit on :spank::boxing:
computer dynos :smash: go..
I'll say 675 hp
680# TQ
It should definitely put a dent in your Wallet (buying Tires! :thumbup:)
For comparison's sake, I have something kinda similar, in that the Duration is the same (.248/.254 @ .050 & 110 LSA), 10.2:1, however my Lift is .680, my Heads are AFR 315's and it's a 540-my Engine put out 775.5 hp & 740# TQ-
my 454 at 8.75 to 1 made 525 ft lb and 500hp
I'm assuming a 750 carb as I dont know what a 850 bearclaw is.
Head probably only flows about 340 at 0.600in lift.
Cam is too small for a really big hp number but will run well on the street. With a bigger cam, and more compression, you could get 750hp.
ever hear of a guy called barry grant
or his later line of carb demons
Ooh yeah, that guy.
The last sooper-duper BG carb I dynoed would not maintain a consistent A/F ratio after sending it back to be rubbed on a few times.
I use Willys or Braswell cuz I dont have time to straighten out some shiny carb from Summit.
I have built and dynoed almost the same engine you want to build, except the cam I used was even smaller for use in a daily driven car, the disp was 496, and the intake was a dual plane. That engine made 575hp on pump 93.
Banned
Discussion Starter · #8 ·
Ooh yeah, that guy.
oh, so you're use'n 3000.oo carbs.. how much for that bridge again?
the bearclaw and demons pre 2009 are fine.. like everyone else he started cutting corners to stay in biz.. it didn't work..
as far as "that guy"
he IS the reason holleys carbs are 100x better than the garbage they sent out the door before he came along.. it forced holley to make better parts..
On a real racing engine...yes, I have spent over $3k for a single carb. I have spent $4k on a gauge legal two barrel for a LMSC engine just to get 10hp more than a $2k carb.
I gave away the 850 BG I mentioned and I would not take another one if they were free. Good luck with your project.
Banned
Discussion Starter · #10 ·
love the way you compair a 2-3-4 thousand dollar piece to a 350.oo-550.oo one.. comical at best
want to compair a 20 dollar cast piston to a 190.oo one next..
Im going to guess 700 hp plus or minus depending on final choice of parts. The 106 icl is curious for that large of engine.Use an 850 X as a minimum size.The flow numbers are important for a better guess.
Banned
Discussion Starter · #15 ·
the 106icl was because I told them I'd be spraying it.. and it was going in a 70 chevelle with 4.10's thats was more fun, and start with safe.. thats why the cam is mighty small for that intake track..
start mild, get car sorted then up the power.. now going in truck that will need to be sorted just to get it to hook and go..
plus I've never run a 106 cam, wanted to try one..
1 - 15 of 15 Posts
