Hello everyone, the other day I decided to try and spin my new cam up to 6500 RPM as it's advertised to make power that high. When I got to about 6300 RPM it started missing and power flattened out, it sounded/felt like I hit a rev limiter. I thought it was odd so I let off and cruised it back home with normal driving, and it acted fine. I pulled the valve cover to check lash and I noticed about half the rockers on the passenger side cylinder head were loose as hell, then I pulled the pushrods out and found that about 5 or 6 were bent (1 being bent pretty badly). I'm just curious as to what could of caused this???
It's an Isky Z-25 solid flat tappet cam with Lunati solid lifters, and Comp 986-16 1.430" dual valve springs with damper (132 on the seat and 290 open) installed on Edelbrock performer RPM heads. I installed the valve springs myself, and made sure to check and shim each valve spring to the proper installed height of 1.750" +/- .020". I checked the seat pressures on the head and they fell right around 130lbs. Also the valve springs are seated in their pockets, it looks like they were machined for a 1.460" or 1.470" spring so there is a little bit of side clearance in the pockets.
The only thing I can think of it being is improper pushrod length. I have stock replacement Sealed Power 7.795" pushrods in there, but I overlooked changing them after I had some machine work done (heads decked .040" and block decked .010" for a total of .050").
Is it possible that pushrods being .050" too long caused this? But why only on one head and not the other? (I checked the other side and lash was fine and all the pushrods were straight).
Maybe stock replacement pushrods don't like RPM above 6000 or too much spring pressure for them???
Help me out here guys! I'm a bit lost.
