sunsetdart said:
Having done custom painting for 30+ yrs, I have found that using any good brand name from start to finish is the way to go. PPG, Dupont, BASF, just to name a few are how I would start. I recommend sticking with ONE name from primer to finish clear. If you mix brand names, sometimes it can bite you in the *** down the road. The main thing with doing any paint job is preparation..........it is 95% of the paint job. If prep is shoddy, the paint will be too.
Absoloutly!! :thumbup:
Also there is Sikkens.
Personally, I put PPG and Sikkens, at the top of the list.
But whatever you pick, stick with it, from the bottom up.
"Experience hath shewn", when you buy primer from one, ('cause it's less expensive), then paint from another, ('cause it's less expensive), and clear from yet another, ('cause it's less expensive), you'll have trouble later, and won't know exactly what caused it.
If you stick with one system from the ground up, you most likely won't have any trouble, and if you do, you can go back to the manufacturer, and they will do what it takes to help.
Thanx
Shorty
