I used to have all my stuff in a garage, but I've recently had to move and now my less important stuff (yeah right, its all important) has to stay outside on a concrete pad. Right now all I have out there is an olds 403 and its tranny. I have it covered up tightly with a tarp, but I don't know if this is sufficient. It doesn't have a carb on it and I feel like I should bolt some type of a plate on the intake to cover it up better. What do you guys do when you have to keep stuff outside? Also, when I first put it out there, I didn't have a tarp so I covered it up with a garbage bag. Unfortunately the dip stick tube got knocked out of the tranny and I'm sure some water got inside when it rained. I guess I need to remove the pan, drain all the fluid/water, replace the pan and refill with fluid. Will this keep the trans in good shape? I'm also a little paranoid that some water may have gotten inside the engine, so I was thinking about removing the plugs, squirting a little oil inside, turning it over a few times, and then replacing the plugs and caping off the intake. Does this sound alright? I just want to keep this stuff in good shape while its outside. I'd hate to see it deteriorate.
Thanks,
Rex
Thanks,
Rex
