I have a Barry Grant 1402010VE 750 with vacuum secondaries that has a peculiar problem: once the motor has warmed up, the throttle will not return to the curb idle setting. It hangs around 1500 instead of its normal idle of 800. I've removed the entire air cleaner assembly, disconnected the throttle cable, (but left both springs attached), and even disconnected the secondary linkage trying to eliminate some sort of bind. There is no choke or choke linkage orfast idle cam or so on.
When the motor is racing at 1500, I can very gently press the primary shaft linkage home and with very little effort, and it returns to its home position at 800 rpm. Because this only occurs when the motor is fully warmed up, (180d thermostat), I suspected a heat related base plate warpage causing a bind?. (1979 Pontiac Trans AM, W72 w/ Edelbrock Performer RPM 7156 intake.) And because of the shaker hood scoop clearance, I'm not using any sort of thermal/insulator gasket, just the basic flange gasket.
I tore down the carb and removed the primary butterflies & shafts to inspect, expecting to find tattle-tale wear marks that would indicate binding but nada. BG troubleshooting guide suggests that the butterflies are not aligned, rubbing the bores but after several adjustments, nothing!
Has anybody else experienced this sort of issue on a BG carb? Solutions? Many thanks!
