I have a stupid question. Where is the oil pressure sender located on a 1972 402 Big Block Chevy.This block came to me with plugs everywhere. I know it's somewhere next to the oil filter but which hole?Can someone send me a pic if available.
Usually the oil pressure is tapped into the hole just above the oil filter boss. Some blocks use a larger hole than others. It is tapped standard pipe thread.
Oil pressure readings can be taken from any of the lower left side oil galley plugs. Including the front one.
http://www.warsprints.com
I don't have a pic but the one I use on my 461 is toward the front of the block on the driver side. It is located below and forward of the front freeze plug. That will give you a more accurate indication of the oil pressure to the front main. It is a 1/4" NPT hole.
