Glad To Be Here
I've got a question that I should know the answer to.
I'm just not sure so I'm posting it here.
I've installed hydraulic brakes many times and had no problem in bleeding them. None had a power booster though.
On my new project I am installing disc brakes all around and am using a dual diaphram booster/MC combo. It is mounted below the floor.
Here's the question. Do I bleed this system the same way as one without a booster? Will the pumping of the pedal mess up the booster when there is no vacuum on it?
I just don't want to mess the booster up before I get to try out the brakes.
Another question.
Does the adjustable proportioning valve (for the rear brakes) get installed in the line before or after the 2psi residual valve? I have seen diagrams showing it both before and after the residual valve.
Thanks in advance.
You won't hurt the booster.
One thing I have been wondering though. Does your MC have to be higher than your calipres? I would think that gravity would cause it to overflow if it is lower.
Tazz
buy a vaccum bleeder pump
I got tired of the pump and hold method.......the pump isn't that expensive. There are books on making up new brake setups, the book isn't expensive either.
Tazz
Rat Rods Rule!
