I just changed the single diaphragm booster shown in this photo to a double diaprhagm booster, so had to bleed the front and rear brakes. The car has 4 wheel Wilwood disc brakes. When bleeding the front calipers, I get probably 4 times as much fluid with each pump as I get from the rear calipers. Is this normal? I know the front brakes do most of the braking, but I would have thought that the amount of fluid pushed out would be approximately the same at each caliper? Thanks, Bill
