As in my last post, I just finished priming my 49 Chevy with SPI epoxy primer, awesome stuff. I am now planning on reworking the filler that I removed on stripping of the vehicle. I have scratch built composite boats and repainted cars. The cars did not need any bodywork to speak of, just a refinish, so not much filler work experience there. I have done max amounts of filler and finishing on marine epoxy with micro boons, putty, and long boarding for dark colors. I have 18 plus years of finishing experience in manufacturing, so that may help some as well.
I have read Martins posts about filler basics which I think I understand, but I have some more basic questions, sooooo, here they go.
1.) I have bought a gallon of Evercoat rage, and I am wondering how much should I reasonably mix at one time? For speed, do you fill and let 1 area cure while sanding another area.
2.) I am used to measuring everything very accurately, and on the can, the instructions just say to put down a 4" glob, and run a ribbon of hardener through it. Seems to me that there would be more to it?
3.) I have various areas including the roof that have areas of small dents. They look like someone has done some hammering on them already and filled them in the past. I think they have been worked as good as they may get, so I am thinking of just refilling. So my question is, fill and skim coat. If that is correct, what do I do if the filler comes level before I skim coat? Or do I just put enough filler to fill dents shy of level and then skim coat, or is that all very unlikely?
4.) I have a couple types of DA's, various grinders and long board (18"). Should I just long board everything flush, skim coat and then long board that to level surface and 180 grit? Is there a better sequence or tools?
5.) I have read that filler will absorb moisture, so how soon do you HAVE to cover filler. If I fill an area on a Sunday and do not finish it, can I leave it until the next day, next week for coating?
Thanks in advance for help on the many questions :welcome:
