Bumping this because I'm trying to figure out a rotisserie to handle that body weight. Been scribbling and reading all through Monday Night Football.
The stands with pivots are no trouble; just mimic the design of several engine stands on the market and the designs of rotisseries found in the forum. The main problem appears to me to be avoiding flexing the body while rotating it without a frame under it. 'Shine' posted something about not trusting body rotisseries that only support at the ends of the body. He built a perimeter framework to support the body in his rotisserie. (Discussion seen here:
http://www.hotrodders.com/forum/tilter-rotisserie-ramp-79099.html located using the Hotrodders Knowledge Base:
http://www.hotrodders.com/kb/ (thanks, Jon!)).
My measurements of the image of the body instead of the body itself weren't far off: Actual length is 136" same as image, width is 72" at the old girl's hips instead of 66", and height is 54" instead of 55". Plugging those numbers into BillyShope's simplified version of Redsdad's formula yields ~705. Since the body narrows from rear to front, it's likely less than that, but 650 - 700 is close enough.
According to
http://www.alvinindustrial.com/info/info_02.htm a 2" sch. 40 pipe supported at both ends will carry 1074 lbs, evenly distributed, on a 10'-0" (120") span. I'm assuming that's a dead load. If I make a rectangular frame out of that pipe, 54" W x 136" L, with brackets from it to the regular body mount points, that gives me access to a lot more of the underside of the body than using the car's frame in the rotisserie.
Anybody care to give opinion on whether that pipe framework will support the body properly throughout rotation? I've never attempted anything like this before, so I don't have any past experience on which to base a judgement.
