Vanetta. Do you have enough wood to use as a pattern? Just take your time and bend it right. For the wood it's self.
I know early chevy have alot of wood.
you might try <a href="http://www.chevywood.com" target="_blank">www.chevywood.com</a> they might help you. make sure you put some of the wood back in for the tack strip for the interior. O if you don't use wood use square tubing that way it can be drilled for the push pins like they use on door panels. some call them push pins,xmas trees, push plugs, keepers,
