Here are a couple runs from the last time I went out.
DATE 8/25/2006
Time of Day 7:00 PM 7:43 PM
Reaction 0.1091 0.0749
60 ft 2.2149 2.2151
330 ft 5.9349 5.9570
1/8 ET 9.0199 9.0191
1/8 MPH 79.49 80.35
1000' ET 11.6748 11.6441
1/4 ET 13.9148 13.8720
1/4 MPH 100.65 100.68
My transmission gearing is 1st-2.64, 2nd-1.75, 3rd-1.34 & 4th 1-1.
Rear gears are 3.08.
Flywheel weight I do not know.
Tire size is 275/60/15 or 27.99.
Launch rpm is 4000-4500.
It does not fall flat during the run just on launch If I hook up. On the two runs I have posted I did not bog because I spun instead. It only falls on its face if it hooks up and does not spin. I believe the valves are adjusted correctly and the timing is at 16 initial and 36 all in by about 3200 rpm. this is to the best of my limited knowledge with trying to tune the thing myself.
DATE 8/25/2006
60 ft 2.2149 2.2151
1/8 MPH 79.49 80.35
