My 305 had a supercharger installed the begining of the month. There have been a few hurdles to deal with. My fuel pump went after changing the pump outlets 90's. The fuel pressure is now stable after replacement. I have been recurving my distributor every few days. There is power, but at higher rpms it seems like power is not ramping up.
build
305 rebulit short 8.9:1
peformer cam
Ls6 beehives little retainers
vortec 906 heads 60cc
E force 122 eaton supercharger
650 cfm AVS
E curve MSD no box
3000 stall
3.73 8.5 rear 28" tire
The manual explains that timing should be reduced 2 degrees for every one lbs of boost. It also recomends a MSD retard boost timing box which I really dont want for 5-6 psi . My curve has been 12 intial 20 more at 3000 rpm for 32 . 8 in the can at 10 " vacuum. After the supercharger locked out at 20 works surprisingly well. The faster the charger spins the more power it makes all the way up. At 10 intial plus 15 at 3000 works good too. Anymore than 25 total after 3000 doesnt work well. The gas is 89 octane.
I do not want to use the MSD box and boost retard. What is the normal acceptable timing curve for a supercharged mild engine? 20 and 25 sound a little short for totals. This also affects normal cruising. Has almost brutal throttle response cruising without the higher timing.
If I go down in plug heat range more will that allow higher total numbers?
Good news, mpg has not changed much.
As the charge density (molecules of fuel and air) inside the cylinder goes up so does the speed of the burn. This also has a dependency upon turbulence of the mixture inside the cylinder.
An unsupercharged engine with a moderate cam from idle to legal cruise speeds has low charge density and turbulence. Therefore, in order to get the burn to occur so as to place the maximum cylinder pressure at the optimum piston position in its bore travel to extract the best power in moderate conditions it takes quite a bit of advance. However, as engine speed picks up and the throttle is opened the density and turbulence within the cylinder substantially increase which speeds the burn rate such that the optimum advance is achieved around 3000 RPM where no further advance is needed in spite of the significant reduction in burn time. For a normally aspirated engine running at atmospheric pressure the needed advance is about 32 to 38 degrees this depends a lot on cam timing, compression ratio, combustion chamber shape, spark plug location and heat range.
When supercharging is introduced the mixture density and turbulence inside the cylinder is increased which reduces burn time thus reducing the need for as much advance as an unboosted engine. The super charger manufacturer in your case recommends removing 2 degrees per pound of boost. Detonation is the limiting factor as to how much boost and how much advance the engine will accept before blowing some expensive part to pieces (usually a piston often taking other things with it). The boundary can be pushed around with changing mixtures rich tend to cool the cylinder by the energy it takes to phase change the extra fuel from liquid to vapor and physically interferes with the flame travel forcing the fire around large molecules adding distance and time. Adding alcohol and or water injection does a similar thing where the phase change absorbs energy (heat) and adds burn time by physically adding distance to the flame front as it tries to get around the globules of liquid. This should not be confused with burning alcohol as a fuel which brings what appears to greater octane resistance, this is a function of the previous descriptions of interference with the cylinder temps and flame front speeds but goes much further into the heat energy difference lesser of alcohol against equal weights of gasoline. So pure alcohol takes a lot more compression to extract its heat energy in the burn.
All of this is to say that while you have instructions from the manufacturer, you do have a unique combination and will have to tease out what set up will work with the engine configuration you've built and the fuel you wish to use. Frankly I much prefer the MSD retard device as electronic control of the advance/retard system is a lot more discrete and reliable than the old vacuum and centrifugal systems.
As the charge density (molecules of fuel and air) inside the cylinder goes up so does the speed of the burn. This also has a dependency upon turbulance of the mixture inside the cylinder.
An unsupercharged engine with a moderate cam from idle to legal cruise speeds has low charge density and turbulance. Therefore, in order to get the burn to occur so as to place the maximium cylinder pressure at the optimium piston position in its bore travel to extract the best power in moderate conditions it takes quite a bit of advance. However, as engine speed picks up and the throttle is opened the density and turbulance within the cylinder substantially increase which speeds the burn rate such that the optimium advance is achieved around 3000 RPM where no further advance is needed inspite of the significant reduction in burn time. For a normally aispirated engine running at atmospheric pressure the needed advance is about 32 to 38 degrees this depends a lot on cam timing, compression ratio, combustion chamber shape and spark plug location.
When supercharging is introduced the mixture density and turbulance inside the cylinder is increased which reduces burn time thus reducing the need for as much advance as an unboosted engine. The super charger manufacturer in your case recommends removing 2 degrees per pound of boost. Detonation is the limiting factor as to how much boost and how much advance the engine will accept before blowing some expensive part to pieces (usually a piston often taking other things with it). The boundry can be pushed around with changing mixtures rich tend to cool the cylinder by the energy it takes to phase change the extra fuel from liquid to vapor and physially interfers with the flame travel forcing the fire around large molecules adding distance and time. Adding alcohol and or water injection does a similar thing where the phase change absorbes energy (heat) and adds burn time by physiaclly adding distance to the flame front as it tries to get around the globules of liquid. This should not be confused with burning alcohol as a fuel which brings what appears to greater octane resistance, this is a function of the previous descritons of interferance with the cylinder temps and flame front speeds but goes much further into the heat energy difference lessor of alcohol against equal weights of gasoline. So pure alcohol takes a lot more compression to extract it's heat energy in the burn.
All of this is to say that while you have instructions from the manufacturer, you do have a unique combination and will have to tease out what set up will work with the engine configuation you've built and the fuel you wish to use. Frankly I much prefer the MSD retard device as electronic control of the advance/retard system is a lot more descrete and reliable than the old vacuum and centrifugal systems.
