Guys as you might have gathered from my previous post I am in
the middle of a tear down and re-build of a Borg warner T5 from my
1984 camaro.
Now to my question. Do any of you know how the fifth gear ratios are
calculated. In my case I have 2 gears which make up the fifth gear which
I believe is .72 final ratio.
The larger helical gear has 55 teeth and the smaller one has 31.
So what I am trying to figure out is how the final ratio is calculated.
I believe for that year transmission I may be able to select different
ratios for the fifth gear set , so any info you got would be most
appreciated..
Thanks... X711.
1984 camaro.
appreciated..
Thanks... X711.
