Hi all, as many of you know I had all sorts of problems with my 4-wheel disk brake conversion. The primary problem was a defective master cylinder. I also installed a vacuum pump which really made the brakes even better.
My 8" dual diaphragm booster requires 18" of vacuum. My pump running all the time pulls 25".
What is the best option to control the pump?
#1 put it on a relay and let it run all the time?
#2 use a vacuum switch to control the pump?
#3 use the brake light switch to control the pump?
Thanks!
Thanks!
