Hi I have a 1988 Toyota pickup I replaced all the rear cylinders and the calipers and brakes and rotors on the front , replacet master cylinder emergency cables about 8 months ago,I was driving to work stepped on the brake and it went too the floor, the emergcey brake became loose also.
it seems like it needs adjustment maybe it has something to do with it I don't know.The cylinders aren't leaking no fluid on any of the tires, maybe i need to bleed the lines? but why did the pedal just go down , new master cylinder is bad? booster is bad?
