92 isuzu rodeo, brake pedal over a corse of about 2 miles went all the way to the floor and the brake/anti lock light came on when the pedal was on the floor. The brakes no longer work properly and only slightly work when the pedal is on the floor.
Did'nt have much time to check everything, but I did a quick check on the fluid and it was full in the master cylinder, checked the pads and they are low, but still have material. My guess is that the master cylinder has failed, seen this a many times, but on older viehicles and also always seen the master cylinder bleed on the sides when it happens, no brake fluid leaking anywhere. Calipers are not leaking either. Could this be as simple as pulling a fuse out for the anti lock? Or is it really something else I'm not seeing. There is also some kind bridge installed after the master cylinder(from the factory) where the lines connect too, and then they go to each caliper.
So what do you all think, havent spent more than 5 mins looking at it, it's cold and raining here right now. I have about 3 hours to repair it tomorrow morning.
