1 - 2 of 2 Posts
I have a chrysler dual master cylinder, 4 wheel disc, is the larger of the 2 reservoirs for the front brakes? and when I tee off to each front wheel, should each line be of equal length?
Larger reservoir is for the front brakes.
It doesn't really matter if the front brake hard lines are the exact same length. The Tee will do fine on the driver's side frame rail (some are there from the factory).
1 - 2 of 2 Posts
