You will probably have to install diodes in the turn signal wiring to eliminate "back feeding" from the brake light switch. If the turn signals are on seperate toggle switches, you will need two diodes. These will need to be placed somewhere between the brake light and the toggle switches. Once you do that, terminate the wire from the brake light switch "after" the diodes. If you could attach a diagram of what you have, it would be helpful.smokey626 said:Ok, I've built a kit car that has a steering column with no turn signal switch built in so the turn signals are on separate toggle switches. How do I wire in the brake light switch so the brake lights work corretly?Thanks!
Smokey
Why not. They are very inexpensive. If this solves your problem, why not buy 2 $8 switches?smokey626 said:That's a great schematic but I'm not using DPDT switches....
