So i have a real big concern, long story short i had a real big problem stopping my truck ive ended up in the middle of the intersection before. So i totaled my truck cause i couldnt stop the light turned yellow i went, and some girl wasnt paying attention, bam!i hit her went over her car and bent my frame. My truck is a 77 k10 4 inch lift 35s 355 th350 np203 nothing extreme my brakes were good but they werent good enough. Im going to one tons and 38s and some engine upgrades so ima need them (new frame 8 inches)
So that brings me to my questions
1. hydro assist good idea
2. i heard a bigger piston master cylinders? also i heard you could get rid of the brake booster by upgrading the size so no need for vacuum
3. Bigger piston calpers front and back do they have them for dana 60 and 14 ff?
4. Rotor size 13 in? So i want to run dana 60 and 14 ff i heard 15 inch rims will work with shaving the calipers not a problem but i cant run a bigger rotor so i was told 17s to run a 13 inch rotor would having one ton brakes and stock rotor size with slotted and cross drilled work good or would i benifit more with 17 inch rims and bigger rotor
thx for the answers just for future references really, im in the works of getting my axles so when i buy rims i wanna know if i could run 15s or would 17s be better to run, this truck is taken everywhere mud, sand, water , some rocks that are not too crazy here in AZ
