Rathimis,
If your truck has factory turn-signals here is how the power gets to the brake lights.
Battery voltage passes through a fuse and then into the brake light switch.
Here is where it gets a little mind twisting.
When you step on the brake pedal the brake light switch allows voltage to go up through the turn signal switch, and as long as you are not turning, this voltage just passes through to the rear brake light bulbs.
Now if you are turning "right" then the brake light voltage is canceled form going to the right rear light bulb in the turn signal switch. But still allows brake voltake to go the the left rear light bulb.
The turn signal voltage is put into the wires that go to the right front turn light and the right rear turn light and passes through the "flasher" so the two lights flash.
I hope this helps
Scholman
