Hi there
The first thing I would do is find out exactly what's dragging, all wheels, front, rear, or just one wheel? The way I do this is to drive your rod till the brake start to drag, then jump out and check the wheel temps with a inferred gun, this will pinpoint which (or all) wheels are sticking. Remeber to stop the car before jumping out:thumbup:
The residual valves that I know of would make things worse as their job is to hold a little bit of pressure in the braking system...its been along time since I have seen them used, so I can't comment for sure
Do you know which/how many wheel are dragging? Have you checked it? I have seen everything from bad m/c to brake lines cause this issue.
Regards
