I have a 1988 Toyota pickup
I changed the wheel cylinders and master cylinder rotors and calipers about 8 months ago everything was good then last week I had to hit my brakes hard in order to stop before hitting the car in front of me. the peddle went down to the floor after that, I checked the rear brake cylinders one had fluid inside the boots I changed with another cylinder i had re bleed the system , the brakes worked ok then I had to stop short again now the brake peddle is down almost to the floor again , they still ar working but not good.
should i replace the rear cylinders or master cylinder don't see any fluid leaking, ever hear of this problem? I need to check the whole system again I guess
