Hello. Got an interesting problem for you all. On my 75 Pontiac Astre (Vega), I'm trying to get it on the road. It's been sitting for a long time while I built a new core support to fix the cooling problems. Well that problems gone, now I've got a brake problem.
After I drive it for a while, about 5-10 minutes, my front brakes gradually start to get applied. At first I thought it was a brake line heating up behind the engine, but I relocated that under the car and it still does it. The brakes are all of a wrecked S10. The master cylinder is a reman 77 Eldorado unit. The proportioning valve is a Wilwood unit inline to the rear brakes only.
Any ideas? I first thought it was heating the fluid up, but I felt the master cylinder after running it and it was not even warm. Now I'm thinking it's coincidental... not as the car is warming up, but maybe it's building up pressure as I apply the brakes more? So I guess I'm looking at either the master cylinder, or the calipers. I'm thinking master cylinder, since it doesn't pull to one side like a caliper is going bad.
What do you all think? Thanks in advance. Josh
