1 - 12 of 12 Posts
I'm thinking about running 10-30W Valvoline VR-1 racing oil for the start up of a new engine that has a roller cam and roller lifters. I'm also planning to use some Lucas ZZDP additive. I plan to stay with the VR-1 down the road as well. My question has to do with regular vs. full synthetic. Also, would you continue to add the ZZDP on all future oil changes?
True Hotrodder
Topic says "Break In Oil" and I know everybody pushes this mess and obviously you don't need it with a roller cam setup BUT my take is to go with a 10w30 Valvoline or a straight 30w Valvoline if you can find it for the first 20-30 minutes. This will help the rings to seat. Drop the oil and filter, check it out and then switch to your VR-1. I don't like that stuff on the street but everyone to their own.
  • Like
Reactions: Molon Labe
Driven BR40 break in oil and Driven XP7 or XP9 Synthetic would be my choice. You dont need a 20w50 oil for a cruiser; theres nothing to gain. Hell you could run Mobil-1 10w30 and be fine.
Im assuming when you say factory clearences, we are talking 1970s/80s stuff here. Driven does have some oils they recommend for certain clearences and applications
IF the engine is properly assembled, using clean parts and properly lubed prior to start up; its unnecessary if you are using a good quality oil that is appropriate for that application.
VR1 is a very high quality oil, but you're not using it in an application where you're going to realize all its benefits either.
Spend the money on Wix (Napa Gold) filters though.
The walmart full synthetic stuff is actually a really good deal. I use a ac delco filter/wix. I been using it for over a year and am impressed.
This is cheap enough you can do traditional 3k oil changes and clean a dirty engine while paying less then name brand dino oil.
For break in or a solid the Driven oil is my go to. The stuff has the proper additives that justify the price. But once a roller is broke in switching to the full synthetic walmart oil will keep your engine and wallet happy.
For a break-in, you want an oil that flows instantly once it starts. I use 10w-30 VR1 and so far so good. Every day driving I use Kendall 20w-50 racing oil. Regular mineral base, no synthetic since I change it once a year. I only drive the car 3000 miles a year.
1 - 12 of 12 Posts
