Hey guys have a 383 in 73 impala I know the rpms and run time thats not the problem. The car fires but I'm get backfiring from exhuast. I'm on top dead center with both valves closed on zero but my distributor is kinda points between one and center like a tooth off should I keep playing with it untill it exactly at one? second should I try to set the timing will running or try to smooth out as much as possible while run durning break in? My fear is golling the bearing if not broke in right.
Can you set the timing up at 10 degrees befor hand that way it not off when start up? Don't know how if possible please explain in full detail or video something so I can refer to. When I watch break in videos they start right up as if timing was done before hand?
