I thought it would be great idea to replace my water pump while having my radiator out of the vehicle. Turns out, it was a very, very bad idea. I broke two of the four bolts holding on the water pump. They are VERY rusty and old. I thought, no problem I will easy out them and if need be re-tap the hole. Wrong again, the easy out has snapped off in the hole!?!? and that is some damn hard steel. A cobalt drill bit will not even make a nick in it.
So, here I am... what next! Does anyone have any ideas to removing the easy out. I have tried everything from heating it with a benzyne torch, tapping it with a chisel to try and turn it in the hole to release the torque and no luck. The easy out is not sticking out of the hole, it is recessed inside the hole approx 1/8".
Any ideas appreciated....
Thanks
7DCRZR
Thanks
7DCRZR
