Hi all
Im restoring the back seat on a coupe and require to source the following in the picture.
The rolled edge with hog ring attachments.
Blue Plant Wood Grass Gas
If anyone has any supplier they know it would be much appreciated
And another question.
are the seat wire outer edges high tensile steel or spring grade wire? Id like to know what to buy.
regards
Whitey327
Wood Branch Twig Composite material Pattern
Hi all
The rolled edge with hog ring attachments. View attachment 624592
regards
Whitey327 View attachment 624591
Find a scrap seat cut the wires out to the length you need. Then use those sleeves you see there you crimp them together. You can make your own sleeves if needed. Best of Luck. Ernie.
