So we’re talking about a V8 conversion to an S15 platform. Is 2200 just to build an engine or for the whole V8 conversion?
For any decent engine life span the 2 bolt main is not suitable for 500 hp beyond visiting it once or twice for a couple seconds. 400 is a more realistic goal on a 350 and the 2 bolt mains will tolerate it for a while.
To do 400 takes modern heads as does 500 starting at the Vortec which still requires substantial modification to the upper valve guides for high lift clearance and the installation of screw in rocker studs, as well as a substantial cam and a compression ratio of 9.5 or more.
Your far better off to start with a 4 bolt block, when you consider the need for a modern chambered head, high rise intake, big 4barrel carb, semi exotic cam with lifters and valve springs, replacement connecting rods, porting the heads a good possibility if factory Vortecs, balancing the crank, improved ignition, revised fuel delivery from the S15’s low pressure electric injection pump. Beefing or replacing the transmission, replacing engine mounts, cooling system a real pain to fit what the V8 needs, drive shaft modification, custom exhaust system, etc. the budget of 2200 dollars unless you have a lot of tools and a machine shop at your disposal looks quite inadequate.
