There is alot of talk about building a 302 , from the 327 to 283 crank swap. I set down and put together what it takes to start from scratch. I actually built this engine and ran it last weekend.
First I went to my local Chevrolet dealer and bought a 350 4bolt brand new bare block with main caps, cost $730. I then found a place that sells eagle cranks and bought an eagle steel 3.00 stroke crankshaft and Rods cost was around $900 for both.
The next thing I debated on was heads and pistons, I found a set of .125 283 flat top 4 valve relief pistons on ebay and bought them for $125 you can order JE TRW or any brand you want in standard 302 size but you will pay $400 to $700 for them and I wanted flat top due to compression levels.
I thought about Aluminum heads but went with a set of cast 64 cc 2.02 1.06 with 200 cc runners. $1000.
I took my block, pistons, rods, neutral balancer and flywheel to a GOOD machine shop and had the assembly balanced, cam bearings installed and pistons fitted. $300
I used a comp cams 280 480 cam kit. with double roller chain. installed an edelbrock airgap intake with an avenger series 670 carb. $700
I put everything together and put it on my engine run stand and it is smooth you can tell that it raps up quicker that a 350 and has that sound.
The point I am making is that they don't make the 302 anymore so you engine nuts like me will have to go out there and build your own. Don't do it at one time buy you parts over the course of a year that is basically what I did.
Now here is the problem got a wife that wants to know what are you going to do with it now you built it, our 67 camaro has a 427 in it and I don't want to pull it out.
