im having someone build a sbc for street not strip. the motor is bored over 30 i went with a mild rv tourque cam elderbrock torker 2 intake factory heads , motor is 70~s 4 bolt main also elderbrock 600cfm 4 barrel carb , with long tube headers . an according to the guy building the motor it has a strong crank an good pistons. does this sound like a good start ? i will be using a posi rear end with 3:08 gear ratio with a 350th trans with a shift kit . can anyone on here give me a good estimate of hp with this set up?
