I just recently put in a built 355 in my 1988 camaro.
engine has:
close to 13:1 compression
2.02/1.60 stainless steel valves
.510 solid lift cam with pretty long duration
significant valve overlap that causes really low manifold vacuum at idle
600 cfm carb
stock t-5 and a 3.08 posi rear end
stock brackets and pulleys of 305 tbi
Dual 2.5" exhaust, no cats
redline @ 6800rpm
poor low end torque
Questions:
Would 3.73 or 4.10's be better (currently 75mph @2000rpm in 5th)?
Would a bigger carb be better?
Would underdrive pullies add significant rwhp?
is 400 whp a good estimate?
would a cowl induction hood be better for the air intake?
other mods have been made:
-exhaust, headers
-mallory fuel pump, 140 gph
-new distributor, 10.5mm wires, ngk plugs
-dual radiator fans, 160 thermostat
-running 170 degrees during casual driving.
considering all the components of the motor, i have a terrible launch and poor 1st gear acceleration. I put the heads on and used arp studs. did a compression test; all good. any other suggestions to make it perform as it should? Really i am looking for the best acceleration and 1/4 ET, but it is my only car for driving 4-5 times a week, 30 miles each trip.
engine has:
600 cfm carb
redline @ 6800rpm
poor low end torque
Questions:
-exhaust, headers
