candrive55 said:
Getting some conflicting info here.
Well the conflicting info is everywhere out there;
Nasty z28
chevy talk
This post repeats its self everywhere and nothing writing in stone.
I would rather not use the oem cover. But if i have to i have to.
Lets put this one to bed;
vortec motor needs oem single chain plastic cover or
Standard sbc double roller with standard cover? (no machine work needed)
The covers are not exactly the same bolt pattern, the non Vortec uses 10 bolts, the Vortec uses 8, 6 of which are the same as the non-Vortec and 2 are different. You can swap them in that the boss face pattern is the same and with some drilling and tapping you can get there.
So the fitting of a standard cover is a definite maybe. The non-Vortec blocks (LT1 & 4 excepted) use a 10 bolt, 2 pin metal cover with no provision for a crank sensor, and have a replaceable crank seal. The 880 Vortec block uses an 8 bolt 2 pin cover with a not replaceable crank seal which includes the mounting boss for the EFI crank sensor. The 6 of the 8 bolts do match to the same locations as they would be found on a 10 bolt cover, so there is a chance of interchange, but it isn't always that simple.
Some early 880 blocks came drilled, and sometimes, tapped with the 10 original bolt cover pattern, they were used with TBI in some non-California applications in 1995 and 96, but most 880's aren't so fashioned. To use a 10 bolt cover on a un-prepped block, assuming you're no longer using Vortec injection which requires a crank position sensor that isn't on the tin cover, you would have to drill and tap the extra holes which would require you remove the intake to collect chips that fall into the engine.
All of this is doable if your skills are up to it. The other way is to ignore the lack of bolts and just put a lot of glue where there aren't any bolts.
When using a standard cover over the OEM roller cam timing set, sometimes you get contact between the chain and cover. The quick and dirty solution is to add gaskets. The one I prefer is to use the two piece removable cover. These however are not made to the newer profile for the lip gasket between the cover and oil pan. You'll have to make trial fits with an older gasket and trim it to fit properly. A lot of extra work, but makes life a lot simpler when you have to go in to change the timing set, crank seal, or the cam.
