Hi
I'm rebuilding my borg warner t10. I found the input shaft needle bearings melted. So i have to undersize and hardener the main and input shaft. Now the new needle bearings dosent fit. Anyone has run a solid bushing?
523932
523933
523934
523935
Speed differences in gears 1, 2 and 3 along with load is too much for a bushing, it will never survive. No pressurized oiling either, it will quickly ruin the bushing....if it goes 1000 miles I will be amazed.
You will need to replace that mainshaft and probably the input shaft too, since the outer race for those needle bearings is the inside of the back of the input shaft.
Looks like the OP is in Argentina. This is going to be tough sledding. You cannot use a bronze bushing, for the reasons Eric stated. You definitely CAN have that spray welded, remachined and heat treated; or source a replacement input and mainshaft. Ed Hartnett is one of the best and ships worldwide. I will send you a private message with his email
Gotta love a turbo!
Watch the "Dicing With Death" series on Amazon Prime and see what some of these guys have to do to keep their vehicles running. One episode had a ring & pinion change in a mud rut, another had a 3 man crew with a rope wrapped around the crank pulley as the "starter"...
Russ
