SonicRainboom
hey guys! so im new here and ive got a problem. the original transmission i had in my 6cyl 63 falcon is crap and is having major problems shifting into the second gear. if i floor it it eventually shifts but only when i reach 40mph, or after just driving for a little bit. it also constantly stalls but i think we got that fixed. some people have recommended a c-4 tranny. other then making adjustments to everything else it would end up fitting and working great. i found one that came out of a 64 ford fairlane removed from 1964 Ford Fairlane .788-inch 24-spline input shaft, stock stall speed 1800-2200- now im not sure if this would be able to fit in t]he car and things like this are well out of my knowledge]right now. id really appreciate the help if any one has any idea of what i should do seeing as looking for an original tranny is pretty hard! Ford C 4 Transmission | eBay
this is the tranny i found
SonicRainboom
Discussion Starter #2
c-4 transmission 63 ford falcon
can i put a c-4 transmission in my 63 ford falcon,. if yes how and what do i need. its a 6cyl
if you beat my boat, well race
the flywheel you have will work.
as long as it has the same bolt pattern on the bell housing it will bolt up just fine.
a new rear crossmember will have to be made, along with a new drive shaft.
i could sell you my 2 speed out of my 62 ranchero as soon as i put my 4 speed manual in.
