hi, i am currently trying to install a 1977 tach gauge cluster into a non tach 1984 chev scottsdale. does any one have an idea where to get schematics for these two gauge clusters, that show wiring diagram. thanx .
Then make another, of what wire color you will be using (either 77 or 84 ) on the Body side of the plug, OR if you make color changes to the field wiring. Plus the NEW wires you will be adding for the TACH circuit. This will be your final schematic.
Save The Plugs from Both Clusters. They may not be compatible, so you may have to use the cluster plug from the 77 on your stock harness. Also cut away as much wire as possible from the donor Harness as , you may need it.
BTW, You might want to apply to Admin for a Screen Name [email protected]
Using your EMAIL as a Screen name leaves your in-box open to all kinds of SPAM, and Virus filled Junk..
We here at the forum do our best to keep this stuff off the board and forums, (you have no idea how much stuff gets deleted and the user's banned before you even see it..) But this leaves your in-box open to these Slugs..If they know they will get deleted and banned here, they'll go right for your EMAIL.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Hot Rod Forum
