1 - 10 of 10 Posts
Burnt out transmission tech.
If a C4 has been sitting inside a garage for 20 years and it was good when it was pulled what are the chances that it's still good after a fluid and seal change?
Some transmissions sit on the shelf for eons and work well. Drop the pan and look for moisture etc. If it is reasonably clean replace front and rear seals and see.
I cleaned it up and took the pan off. Everything looks good but there is some corrosion in the pan mainly underneath the dipstick. I'll probably go ahead and go with it and if it doesn't work I'll deal with it then.
Font Gas Motor vehicle Auto part Metal
616538
1 - 10 of 10 Posts
