Ok i did a stupid human trick.... When i took the valve body apart I got the converter check valve assembly spring. And the throttle pressure check ball spring seperated from the correct spot. I think the longer with more coils spring belongs in the converter check valve assembly,,, Is this correct???? My tech book does not show a clear answer to this......
thanks , Keith
thanks , Keith
