you can also do it off the valve stem with a degreewheel that is referenced to your crankshaft keyway (your balancer's timing mark may have moved If it is a good balancer and you're sure it hasn't shifted you can use the timing mark as a reference.), the only thing you'll need to remove is your accessories and your valve covers. This is assuming the opening/closing ramps are symmetric or very near to it.
