Hi All,
My son and I are building a 383" Chevy with 6.0 "H" beam rods (cap screws) and 1.125" compression height. I've posted the question about rod / lobe contact here before and the concensus opnion was that you needed 0.050" minimum clearance.
Today, we attempted to verify the clearance on an old worn out cam and we could NOT figure out a way to do this! We tried putting a pair of rod / piston assemblies in and there is no way to get any kind of feeler gauge in there.
BUT! In the process, we noticed that on this old (factory) cam which measured 0.405" lift on the good lobes, the lobes are almost "even" with the bearing journals. This is making me think that a "high lift" cam MUST be ground with a smaller base circle. Otherwise the cam would not go into the block.
That being the case, would we be OK with the cam (currently in his driver) we'll be using? It's a Comp XM-276-12 with 0.503" / 0.510" lift. Obviously, we can't check with this cam (but will for sure) until it's swap time, but we'd sure like some assurance it will be a go.
How about some peeps with high lift cams measuring "base circle" vs. the "over the nose" dimension?
Thanks!
Russ
Thanks!
Russ
