Cam Bearing Tools-Front Bearing Help
Well I finally got the motivation to swap cams and timing set on the 307 and the front cam bearing is chipped and wants to peel up a layer in a couple spots and needs replacement
I think to go to local parts store to rent an installer/remover but no longer do this because of apparent miss-use of the tool by renters
And the guy behind the counter took the time to talk to me like im stupid and dont know how to line up the oiling holes and the correct sizes for each bearing bore
Now all of that^^^^ leads me to my actual question, Do the cheaper bearing tools work as well as the more expensive snap on tool??
I do not want to drop 200 dollars on a tool that will not be used often, i dont even want to spend 60-80 on the cheap ones but im stuck between a rock and a hard place
Thanks for any input, it is appreciated!
Jason
Jason
