1 - 2 of 2 Posts
Do I need or should I use a cam button on a SB Chevy with a solid flat tappet cam/ It is a early engine with a roller timing chain. The probelm is with the new Profrom timing cover I bought it wont fit. It will fit under the stock one, but it is in bad shape. If I should use it I will get a different timing cover, but if it is a waste I will not use the button. I always used to put them in to our stock car racing engines, but maybe they were only needed on roller cams.
Thanks,
1 - 2 of 2 Posts
