Chasing dreams with a ball bat
Guys,
Got a quick question: I changed the cam in my 355 sbc, and now it's time to put her back together again.
Is there a way to seal up the timing cover without dropping the pan at all? I have a aluminum timing cover and Moroso oil pan and I think it takes the thick gasket.
ANy tips or pointers would be appreciated. Don't want to have pesky oil leaks.
Premium Member
you need to move the pan if only a little. Most guys just loosen the pan bolts and let it sag a little, you only need a 1/4 inch or so. Get your timing cover sealed up nice, then put your pan up against it and torque everything twice, you should be fine!
K
Member# 3287
Another tip to the above is to trim the sharp corner edges of the timing cover lip that slips into the front of the pan. This is also a lot simpler if you have a one-piece pan gasket.
that's what I'm talking about.
thanks!
What if I reuse the compressed rubber gasket and apply a little silicone to it? Probably better off using the new one?
I don't have any friends to help me.
J/K - my neighbor is always willing to lend a hand. Maybe even my wife if I'm nice and promise "things" to her.
