Thanks for reading.
I have a 350 SBC in a 1988 Chevrolet caprice. Weighs around 4200 lbs. 3.23 rear gears. 200r4 OD transmission. 2000 stall converter.. Factory smog heads.
STOCK highly restrictive exhaust. Stock aluminum dual plane intake.
Must keep these things and a bunch of other stuff due to smog.
The car is a daily driver, and I was going for increased grunt over stock. But gas mileage is more important than ever.
I can get away with a mild cam. At the moment I have a comp cams X4270HR truck cam in the car right now. And truthfully it's over cammed.
The specs are 220/224 @0.050. .474/.474 lift. On 111 LSA
I'm mostly debating between the X42458HR, XR252HR, and XR258HR
Specs X4258HR 206/210 @0.050, .458/.458 lift. On 111 LSA
XR252HR 200/206 @0.050 .472/.480 lift. On 110 LSA
XR258HR 206/212 @0.050 .480/.487 lift. On 110 LSA.
If anyone with more experience could recommend what route I should take and why, I would really appreciate the input.
Thank you.
Thank you.
